Single sign-on for Kerberos on-premise only
This guide will discuss how to set up single sign-on using Microsoft Active Directory.
Conceptual overview
Like every other web application out there, Zammad has its own logic for signing users up, storing their passwords, authenticating them, and managing their sessions.
If your IT department keeps its own user identity store (like Active Directory), Zammad's SSO support allows you to leverage that existing auth system so that anyone with an account on your local intranet will 1) automatically have an account in Zammad and 2) be able to log in with a single click.
TIP
If you don't have this IT infrastructure but still want one-click login, you can use alternatives like GitHub, Google, Facebook and more.
How does it work?
Zammad does not speak Kerberos itself. It provides the endpoint https://your.zammad.host/auth/sso and relies on the web server in front of it to authenticate the user before a request reaches that endpoint. The web server passes the user name along, Zammad looks up the user by their login and starts a session.
The user name can arrive in one of three forms, which Zammad checks in this order:
- the
REMOTE_USERvariable of the web server, only when the web server runs Zammad in its own process - the
Remote-Userrequest header, which Zammad sees asHTTP_REMOTE_USER - the
X-Forwarded-Userrequest header
Which one applies depends on your installation:
- Package installation
- Apache replaces Nginx on the Zammad host, authenticates
/auth/ssoand setsX-Forwarded-User. - Docker stack
- The stack's own Nginx stays in place. An additional container in front of
/auth/ssoauthenticates, setsX-Forwarded-Userand forwards the request to Zammad's application server directly.
INFO
Wait. SSO allows you to sign in with only a username?
In principle, yes.
How is that okay?
In this guide, we configure our web server (Apache) to intercept all requests to the /auth/sso endpoint. Instead of forwarding them to Zammad, Apache initiates a three-sided login process (Kerberos authentication) between the itself, the user, and the Active Directory server.
If Active Directory doesn't recognize the user or their password, Zammad never sees the request, and the session is never created.
What does this all mean?
It means there are many ways you could set up SSO, you don't need to follow this guide or even use Active Directory or Kerberos, but if you don't know what you're doing, you're going to end up with a massive security hole.
Getting started
TIP
Too busy to handle it on your own?
We've got you covered. Our experts offer custom-tailored workshops to get your team up and running fast and with confidence. Just drop us a line!
You will need:
- a Microsoft Active Directory environment with
- root access
- support for AES 256-bit encryption
- a Zammad installation with a fully-qualified domain name (FQDN), either
- a package installation with root access on the host, or
- the Docker stack behind a reverse proxy that terminates TLS and routes by path, such as the Nginx Proxy Manager scenario
- some familiarity with system administration (e.g. Apache configuration)
For best results, set up the LDAP integration to make sure your Active Directory and Zammad user accounts are always in sync. You can find it in Zammad's admin interface under System > Integrations > LDAP.
Step 1: Configure active directory
In the Kerberos authentication scheme, the authentication server (Active Directory) needs to maintain shared secrets with the service (Zammad). To make this possible, we need to register a service principal name (SPN) for Zammad on Active Directory.
INFO
These directions have been confirmed on Windows Server 2016.
1a. Create a service account
You may use an existing service account if you have one. Admin privileges are not required; a normal user account will do.
1b. Reset password
Reset service account password after enabling the "This account supports Kerberos AES 256 bit encryption".
Without this option, the keytab carries only RC4 keys, which current Kerberos libraries reject. The Docker SSO container is one of them.
1c. Register a SPN for Zammad
Replace the following placeholders in the commands below:
<zammad-host>: Zammad FQDN<service-acct>: Service account logon name<password>: Password of the service account (Option/pass *did prove to not work)<domain>: Windows domain<master-domain-controller>: Master domain controller IP/FQD
The commands below will prompt for the users password:
setspn -s HTTP/<zammad-host> <service-acct>ktpass /princ HTTP/<zammad-host>@<DOMAIN> \
/mapuser <service-acct> \
/crypto AES256-SHA1 \
/ptype KRB5_NT_PRINCIPAL \
/pass <password> -SetPass +DumpSalt \
/target <master-domain-controller> \
/out zammad.keytab1d. Note the secret key and version number
This step is for the package installation only. The Docker stack uses the zammad.keytab file written by the command above as it is.
The output of the command above contains important data for Step 2f below:
Using legacy password setting method
Failed to set property 'servicePrincipalName' to 'HTTP/<zammad-host>' on Dn 'CN=Zammad Service,DC=<domain>,DC=<tld>': 0x13.
WARNING: Unable to set SPN mapping data.
If <service-acct> already has an SPN mapping installed for HTTP/<zammad-host>, this is no cause for concern.
Building salt with principalname HTTP/<zammad-host> and domain <domain> (encryption type 18)...
Hashing password with salt "<domain><service-acct>".
Key created.
Output keytab to zammad.keytab:
Keytab version: 0x502
keysize 67 <service-acct>@<domain> ptype 1 (KRB5_NT_PRINCIPAL) vno 3 etype 0x12 (AES256-SHA1) keylength 32 (0x5ee827c30c736dd4095c9cbe146eabc216415b1ddb134db6aabd61be8fdf7fb1) On the last line, take note of:
- the secret key in parentheses at the end (0x5ee827...)
- the secret key version number preceded by
vno(3)
Step 2: Set up the Kerberos endpoint
Next, requests to /auth/sso must pass a web server that performs the Kerberos authentication before they reach Zammad. How you set this up depends on your installation: follow Package installation or Docker installation.
Next, the Zammad host must be configured to support Kerberos (and to accept auth credentials provided by the Active Directory server).
In most cases, you would have to recompile NGINX from source with an extra module to enable Kerberos support. To get around this, we will use Apache, which offers Kerberos support through a plug-in module instead.
INFO
All commands in this section must be run as root (or with sudo).
2a. Turn off NGINX
WARNING
This will take your Zammad instance offline until Apache is fully configured and running.
Turn off Nginx:
sudo systemctl stop nginxKeep it off after reboot:
sudo systemctl disable nginxIf you wish to minimize downtime, you can save this step for last; just bear in mind that Apache will not start if the port it wants to listen on is being used by NGINX.
If you can't complete this tutorial for any reason, simply turn off Apache and restore NGINX:
Details
sudo systemctl stop apache2sudo systemctl disable apache2sudo systemctl enable nginxsudo systemctl start nginx2b. Pre-configure Apache
This documentation expects an already working Apache configuration. You should have a look at the webserver configuration guide before continuing.
2c. Install further Apache dependencies
sudo apt updatesudo apt install krb5-user libapache2-mod-auth-gssapi2d. Enable Apache modules
SSO requires modules that are not enabled by default. By default you can use a2enmod to do so.
a2enmod auth_gssapi rewritesudo systemctl restart apache22e. Configure Kerberos
Kerberos realm configuration is how you tell the Zammad server how to reach the domain controller (Active Directory server).
Replace the following placeholders in the sample config below:
<domain>: Windows domain<domain-controller>: Domain controller IP/FQDN(s)<master-domain-controller>: Master domain controller IP/FQDN (must not be read-only, but can be the same as<domain-controller>)
# /etc/krb5.conf
[libdefaults]
default_realm = <DOMAIN>
default_tkt_enctypes = aes256-cts-hmac-sha1-96
default_tgs_enctypes = aes256-cts-hmac-sha1-96
permitted_enctypes = aes256-cts-hmac-sha1-96
kdc_timesync = 1
ccache_type = 4
forwardable = false
proxiable = false
fcc-mit-ticketflags = false
[realms]
# multiple KDCs ok (one `kdc = ...` definition per line)
<DOMAIN> = {
kdc = <domain-controller>
admin_server = <master-domain-controller>
default_domain = <domain>
# below is only for GSSAPI
auth_to_local = RULE:[1:$1@$0](.*@<domain>)s/@<domain>$//
auth_to_local = DEFAULT
[domain_realm]
.<domain> = <DOMAIN>
<domain> = <DOMAIN>2f. Generate keytab
Apache needs a Kerberos keytab (key table) to manage its shared secrets with the domain controller.
<zammad-host>: Zammad FQDN<domain>: Windows domain<secret-key>: Secret key (omit the leading0x)<vno>: Secret key version number
The secret key and version number were found in Step 1: Configure active directory above.
Enter ktutil:
ktutilAdd keytab:
ktutil: addent -key -p HTTP/<zammad-host>@<DOMAIN> -k <vno> -e aes256-cts
Key for HTTP/<zammad-host>@<domain> (hex): <secret-key>Confirm the entry was added successfully:
ktutil: list
slot KVNO Principal
1 3 HTTP/<zammad-host>@<DOMAIN>Write keytab to disk:
ktutil: wkt /root/zammad.keytabLeave ktutil:
ktutil: quitThen, place the keytab in the Apache config directory and set the appropriate permissions:
sudo mv /root/zammad.keytab /etc/apache2/sudo chown root:www-data /etc/apache2/zammad.keytabsudo chmod 640 /etc/apache2/zammad.keytab2g. Configure Apache
Add the following directive to the end of the virtual host configuration file to create your Kerberos SSO endpoint at /auth/sso:
Replace the following placeholders in the command below:
# /etc/apache2/sites-available/zammad.conf
<LocationMatch "/auth/sso">
SSLRequireSSL
AuthType GSSAPI
AuthName "Your Zammad"
GssapiBasicAuth On
GssapiCredStore keytab:/etc/apache2/zammad.keytab
GssapiLocalName On
require valid-user
RewriteEngine On
RewriteCond %{LA-U:REMOTE_USER} (.+)
RewriteRule . - [E=RU:%1,NS]
RequestHeader set X-Forwarded-User "%{RU}e" env=RU
</LocationMatch>2h. Restart Apache to apply changes
sudo systemctl restart apache2Docker installation
The Docker stack runs its web server inside the zammad-nginx image, so you cannot swap it for Apache as in the package installation. Instead, a small additional container does the Kerberos part: the reverse proxy in front of the stack sends only /auth/sso through it, everything else goes straight to zammad-nginx as before. Zammad and the stack's compose files stay as they are. The SSO container is part of your infrastructure, like the reverse proxy that terminates TLS.
browser ──► reverse proxy (TLS)
├─ /auth/sso ──► zammad-sso ──(Kerberos ok, sets X-Forwarded-User)──► zammad-railsserver
└─ everything else ──────────────────────────────────────────────► zammad-nginx ──► zammad-railsserverThe SSO container forwards /auth/sso to Zammad's application server directly and passes the user name in the X-Forwarded-User header, as the package installation does. One hop fewer, and zammad-nginx is not involved in the login.
INFO
Your reverse proxy can do Kerberos itself?
Then you don't need the SSO container. Configure the proxy to authenticate /auth/sso via Negotiate, put the user name without the realm into the X-Forwarded-User header, drop Remote-User and X-Forwarded-User sent by clients on every path, send /auth/sso to zammad-railsserver:3000, pass all other requests unchanged, and continue with Trusted proxies.
You need:
- the stack behind a reverse proxy that routes by path. This guide uses the Nginx Proxy Manager scenario. Any proxy with path-based routing works the same way. If your proxy runs in a separate compose project, use the external network scenario and add that network to the
zammad-ssoservice in the override file as well, so that the proxy can reach it. - the
zammad.keytabfile written byktpassin 1c. Register a SPN for Zammad, copied to the Docker host. Thektutilstep of the package installation is not needed.
Files
The SSO container consists of the following files next to the stack's docker-compose.yml:
docker-compose.override.yml adds the SSO container to the stack
zammad-sso/ build context of the SSO image
Dockerfile
apache2-foreground
zammad-sso.conf
local/zammad-sso/ files mounted into the container
krb5.conf
zammad.keytabKeep the keytab out of the build context: Docker reads every file in zammad-sso/ when it builds the image, and a keytab that only the container's user may read makes the build fail. The container runs as www-data with user ID 33, so on a Linux host:
sudo chown 33 local/zammad-sso/zammad.keytabsudo chmod 0400 local/zammad-sso/zammad.keytabzammad-sso/Dockerfile builds Apache with mod_auth_gssapi from the Debian packages and runs it unprivileged:
FROM debian:trixie-slim
RUN apt-get update && \
apt-get install -y --no-install-recommends apache2 libapache2-mod-auth-gssapi krb5-user curl && \
rm -rf /var/lib/apt/lists/*
RUN a2enmod auth_gssapi proxy proxy_http headers rewrite && \
a2dissite 000-default
COPY zammad-sso.conf /etc/apache2/sites-available/zammad-sso.conf
RUN a2ensite zammad-sso
# Debian's envvars assigns the APACHE_* variables unconditionally. Turn every
# "export VAR=value" into ": ${VAR:=value}; export VAR", so that values from the
# environment win, the same way the official php:apache image does it.
RUN sed -ri 's/^export ([^=]+)=(.*)$/: ${\1:=\2}\nexport \1/' /etc/apache2/envvars
# Run unprivileged: listen on 8080, pid/lock/logs under /tmp.
ENV APACHE_RUN_DIR=/tmp/apache2 \
APACHE_PID_FILE=/tmp/apache2/apache2.pid \
APACHE_LOCK_DIR=/tmp/apache2 \
APACHE_LOG_DIR=/tmp/apache2
RUN echo 'Listen 8080' > /etc/apache2/ports.conf && \
{ echo 'ServerName zammad-sso'; \
echo 'ErrorLog /proc/self/fd/2'; \
echo 'CustomLog /proc/self/fd/1 combined'; } > /etc/apache2/conf-available/zz-docker.conf && \
a2enconf zz-docker
COPY apache2-foreground /usr/local/bin/apache2-foreground
USER www-data
EXPOSE 8080
# Healthy = the keytab is readable and apache answers /auth/sso with the Negotiate
# challenge (401). A keytab with a wrong key is not detected here: apache still
# answers 401 and logs a GSS ERROR for every sign-in attempt.
HEALTHCHECK --interval=30s --timeout=5s --start-period=10s \
CMD klist -k /etc/apache2/zammad.keytab >/dev/null 2>&1 && \
[ "$(curl -s -o /dev/null -w '%{http_code}' http://localhost:8080/auth/sso)" = "401" ] || exit 1
CMD ["apache2-foreground"]zammad-sso/apache2-foreground starts Apache as the container's main process. Make it executable with chmod +x:
#!/bin/sh
# Start apache directly instead of through apache2ctl, so that it runs as PID 1
# and receives the container's signals. The run directory is created on every
# start and a stale pid file from a previous run is removed.
set -e
. /etc/apache2/envvars
mkdir -p "$APACHE_RUN_DIR" "$APACHE_LOCK_DIR" "$APACHE_LOG_DIR"
rm -f "$APACHE_PID_FILE"
exec apache2 -DFOREGROUND "$@"zammad-sso/zammad-sso.conf authenticates /auth/sso and forwards it to the stack:
<VirtualHost *:8080>
<Location "/auth/sso">
AuthType GSSAPI
AuthName "Zammad SSO"
GssapiAllowedMech krb5
# strips @REALM
GssapiLocalName On
Require valid-user
# inbound client values never survive
RequestHeader unset Remote-User
RequestHeader unset X-Forwarded-User
RewriteEngine On
# don't leak the Negotiate token downstream
RequestHeader unset Authorization
ProxyPreserveHost On
ProxyPass http://zammad-railsserver:3000/auth/sso
ProxyPassReverse http://zammad-railsserver:3000/auth/sso
</Location>
</VirtualHost>Add the zammad-sso service to your docker-compose.override.yml. If the stack has no override file yet, create it from the shipped template, see Customize the stack locally:
services:
zammad-sso:
build: ./zammad-sso
restart: ${RESTART:-always}
volumes:
- ./local/zammad-sso/krb5.conf:/etc/krb5.conf:ro
- ./local/zammad-sso/zammad.keytab:/etc/apache2/zammad.keytab:rolocal/zammad-sso/krb5.conf tells the container how to reach your domain controller. Replace the placeholders as described in 2e. Configure Kerberos:
[libdefaults]
dns_lookup_realm = false
dns_lookup_kdc = false
rdns = false
[realms]
<DOMAIN> = {
[domain_realm]
<domain> = <DOMAIN>Add the override file and the reverse proxy as trusted proxy to your .env:
COMPOSE_FILE=docker-compose.yml:scenarios/add-nginx-proxy-manager.yml:docker-compose.override.yml
ZAMMAD_FQDN=<zammad-host>
ZAMMAD_HTTP_TYPE=https
RAILS_TRUSTED_PROXIES=nginx-proxy-managerThen build and start the stack:
docker compose up -d --buildThe zammad-sso container reports healthy once the keytab is readable and Apache answers /auth/sso with the Kerberos challenge. If it stays unhealthy, the keytab is missing or not readable by user ID 33.
Configure the reverse proxy
In Nginx Proxy Manager:
- Create a proxy host for your Zammad FQDN with scheme
http, forward hostzammad-nginxand port8080. Enable Websockets Support and set up the certificate on the SSL tab. - Add a Custom Location for
/auth/ssowith schemehttp, forward hostzammad-ssoand port8080.
Do not rely on the Advanced field to strip headers: proxy_set_header lines entered there do not reach the generated locations and would only give a false sense of security. Client-sent headers are removed in the SSO container.
With Traefik, the equivalent is a router that points at the SSO container, with a higher priority than the router for the rest of the stack and the rule:
Host(`<zammad-host>`) && PathPrefix(`/auth/sso`)Trusted proxies
Zammad has to trust the reverse proxy, so that it takes the address of the user's browser as the client instead of a container address. That is what RAILS_TRUSTED_PROXIES in .env does. With another proxy, name that one instead, see environment variables. The SSO container does not need to be listed: Zammad takes the address the reverse proxy forwarded and falls back to the sending container only when no untrusted forwarded address is left.
The Trusted SSO Proxy IPs setting in Step 3 then holds the address ranges from which users may sign in via SSO, typically your intranet. A changed value applies after at most 15 seconds. Without the reverse proxy in RAILS_TRUSTED_PROXIES, Zammad takes a container's address as the client, and the setting would have to hold the stack's network range, which admits every container.
WARNING
The setting guards the way in through the reverse proxy only. Inside the stack's network, zammad-railsserver accepts an X-Forwarded-User header from any container, and a container can send the X-Forwarded-For header the check relies on along with it. Keep zammad-railsserver reachable only from the stack's own containers and the SSO container, and set the trusted IPs before you enable SSO.
Portainer
Without shell access to the Docker host, you can build and run the same container through the Portainer UI:
Under Images, choose Build a new image, upload a tarball that contains the three files of
zammad-sso/at its top level (not the directory itself) and tag the image, e.g.zammad-sso:local. The image contains no keytab, so it holds no secret.Under Volumes, choose Add volume and create
zammad-sso-secrets.Put
zammad.keytabandkrb5.confinto the volume. Portainer Business has a volume browser with upload. In the Community Edition, deploy a throwaway container (alpinewith the commandsleep infinity) that mounts the volume at/secrets, paste the files through its console (for example viabase64 -d), set owner33and mode0400on the keytab, and remove the container again.Under Stacks, choose Add stack and deploy the SSO container with the web editor as a stack of its own that joins the Zammad stack's network. Replace
<zammad-stack>with the name of your Zammad stack in Portainer.yamlservices: zammad-sso: image: zammad-sso:local restart: always volumes: - type: volume source: zammad-sso-secrets target: /etc/krb5.conf read_only: true volume: subpath: krb5.conf - type: volume source: zammad-sso-secrets target: /etc/apache2/zammad.keytab read_only: true volume: subpath: zammad.keytab networks: - zammad networks: zammad: external: true name: <zammad-stack>_default volumes: zammad-sso-secrets: external: true
The reverse proxy is configured as above and has to be a trusted proxy of the Zammad stack, see Trusted proxies.
Step 3: Enable SSO in Zammad
Next, enable "Authentication via SSO" in Zammad's admin interface under Settings > Security > Third-party Applications. Make sure to configure the trusted SSO proxy IPs for production systems. For the Docker stack, Trusted proxies explains which addresses belong there.
TIP
On older versions of Zammad, visit https://your.zammad.host/auth/sso to sign in.
Step 4: Configure client system (Windows only)
For the full SSO experience (i.e. for passwordless one-click sign-in), Zammad users must:
- be on the Active Directory server's local intranet; and
- modify their network settings for the Zammad host to be treated as a local intranet server.
Without this step, users must enter their Active Directory credentials during SSO.
TIP
This setting can be centrally managed across the entire intranet using a group policy object (GPO).
- Add your Zammad FQDN in Internet Options under Security > Local Intranet > Sites > Advanced.
- Select "Require server verification (https:) for all sites in this zone".
- Under Security level for this zone > Custom level... > Settings > User Authentication > Logon, select "Automatic logon only in Intranet Zone".
Troubleshooting
- Are all relevant FQDNs/hostnames reachable from your Active Directory and Zammad servers (including each other's)?
- Are the system clocks of your Active Directory and Zammad servers synchronized within five minutes of each other? Kerberos is a time-sensitive protocol!
Errors in Apache logs
TIP
Try raising your Apache log level temporarily.
Add LogLevel debug to your virtual host configuration, then restart the service to apply the changes.
An unsupported mechanism was requested
Does your Active Directory service account have Kerberos AES 256-bit encryption enabled?
If for some reason your server does not support AES 256-bit encryption, the LDAP Wiki has more information about Kerberos encryption types.
Failed to verify krb5 credentials: Key version is not available
Did you use the exact version number (vno) provided by ktpass when generating your keytab?
Try generating it again, just to be sure.
Unspecified GSS failure. Minor code may provide more information (, no key table entry found for HTTP/FQDN@DOMAIN)
Does the service name you provided to setspn exactly match the one you used when generating your keytab?
No key table entry found for HTTP/FQDN@DOMAIN
Does your virtual host configuration's KrbServiceName setting exactly match the service name you provided to setspn?
This setting is case-sensitive.
Warning: Received token seems to be NTLM, which isn't supported by the Kerberos module. Check your IE configuration
Is your Zammad host accessible at an FQDN? This error may indicate that you configured your Zammad host as a numeric IP address instead.
Cannot decrypt ticket for HTTP/FQDN@DOMAIN
Did you make sure to change the password on your Active Directory service account after enabling 256-bit AES encryption?
And did you make sure to register the SPN (with ktpass) and generate your keytab (with ktutil) after changing your password?
Try running kinit -k -t <path to keytab> HTTP/<zammad-host>@<DOMAIN>. If no output is returned, you're good - if you see "kinit: Preauthentication failed while getting initial credentials" your credentials provided were wrong or you used /pass * during ktpass command.
Failed when verifying KDC" and "failed to verify krb5 credentials: Decrypt integrity check failed
Ensure KrbServiceName is the correct ServiceName provided via setspn.
Ensure your Active Directory supports the encryption method configured.
If all above is correct and the rest of FAQ also is ensured, make sure your client does not cache the results. klist purge clears the clients cache - a reboot of your client would do too.
Docker stack
502 Bad Gateway on /auth/sso only, after recreating the SSO container
The reverse proxy still holds the container's old address. Nginx Proxy Manager resolves the name only when it loads its configuration, so reload it: docker compose exec nginx-proxy-manager nginx -s reload.
SSO request from untrusted IP address, after recreating the reverse proxy
Zammad resolves the names in RAILS_TRUSTED_PROXIES when it starts, see environment variables, so it still trusts the proxy's old address, sees the new one as the client and checks it against Trusted SSO Proxy IPs. Restart the services that trust the proxy: docker compose restart zammad-railsserver zammad-websocket.
Signing in via SSO fails although the zammad-sso container is healthy
The health check verifies that the keytab is readable and that Apache issues the Kerberos challenge. It cannot verify the key itself. Check docker compose logs zammad-sso: a line GSS ERROR … cannot decrypt ticket means the keytab does not match the service account's current key, usually because it was exported before the last password reset. Export it again as described in 1c. Register a SPN for Zammad.
