Connect and configure Elasticsearch
TIP
Are you tired of complex setup, configuration, backup and update tasks? Let us handle this stuff for you! 🚀
The easiest and often most cost-effective way to operate Zammad is our cloud service. Give it a try with a free trial instance!
This guide shows you how to connect Zammad with Elasticsearch.
Connect Elasticsearch with Zammad
Set the Elasticsearch URL
Set the Elasticsearch server address; adapt it to your scenario.
zammad run rails r "Setting.set('es_url', 'https://localhost:9200')"Set the Elasticsearch user and password
zammad run rails r "Setting.set('es_user', 'elastic')"Replace <password> with the one you got during the installation of Elasticsearch. In case you need to create a new password, run /usr/share/elasticsearch/bin/elasticsearch-reset-password -u elastic.
zammad run rails r "Setting.set('es_password', '<password>')"Add certificate to Zammad
Add it via Rails console
In case you are installing a new Zammad and didn't run through the getting started wizard already, add the certificate via console:
sudo cat /etc/elasticsearch/certs/http_ca.crt | zammad run rails r "SSLCertificate.create!(certificate: STDIN.read)"Add it via UI
In case you already have a running and configured Zammad, you can add the certificate in Zammad's admin settings (Settings > Security > SSL Certificates) as an alternative. To show and copy the auto-generated certificate from Elasticsearch, run:
sudo cat /etc/elasticsearch/certs/http_ca.crtTo add it in Zammad, either upload the certificate file or paste the content in the dialog. Make sure to copy/paste the delimiters (e.g. -----BEGIN CERTIFICATE-----) too.
Build/rebuild the searchindex
Without specifying CPU cores to use:
zammad run rake zammad:searchindex:rebuildWith specifying CPU cores to use (example 8):
zammad run rake zammad:searchindex:rebuild[8]Optional settings
We collected some useful settings you may want to apply. For further information please have a look at Elastic's documentation.
Index namespacing
Useful when connecting multiple services or Zammad instances to a single Elasticsearch server (to prevent name collisions during indexing).
zammad run rails r "Setting.set('es_index', Socket.gethostname.downcase + '_zammad')"File-attachment indexing rules
Zammad supports searching in file attachments, which means Elasticsearch has to index those, too. Limiting such indexing can help preserve system resources.
Files with these extensions will not be indexed:
zammad run rails r "Setting.set('es_attachment_ignore',\
[ '.png', '.jpg', '.jpeg', '.mpeg', '.mpg', '.mov', '.bin', '.exe', '.box', '.mbox' ] )"Files larger than this size (in MB) will not be indexed:
zammad run rails r "Setting.set('es_attachment_max_size_in_mb', 50)"Asciifold
By default, the Asciifold feature of Elasticsearch is enabled. This can be useful if you deal with text which includes diacritics and/or umlauts.
In case you need a more exact search, you can turn it off:
zammad run rails r "Setting.set('es_asciifolding', false)"SSL verification
You can disable SSL verification, which is not recommended. Default is true.
zammad run rails r "Setting.set('es_ssl_verify', false)"If you want to use custom certificates, you can find information about how to use them in Zammad's admin settings (Settings > Security > SSL Certificates).
Troubleshooting
TIP
Troubleshooting unsuccessful or issue not described?
If you can't solve your issue using the provided troubleshooting steps or can't find your particular issue described here, feel free to ask the community for technical assistance.
Data missing from the web-UI / search data missing or incomplete
A commonly reported issue is data missing from the Web-UI. This could be tickets, articles, users or anything else indexed by Elasticsearch and can be caused by missing or incomplete indexes.
If you are experiencing this issue and installed Elasticsearch according to our installation guide, please follow these steps to make sure Elasticsearch is working correctly.
Step 1: Verify Elasticsearch is running
sudo systemctl status elasticsearchThis should output something like the following, make sure it says Active: active (running):
● elasticsearch.service - Elasticsearch
Loaded: loaded (/lib/systemd/system/elasticsearch.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2021-07-20 09:38:21 UTC; 1h 4min ago
Docs: https://www.elastic.co
Main PID: 1790 (java)Otherwise, try restarting it and check again:
sudo systemctl restart elasticsearchWARNING
If this fails, your Elasticsearch installation is probably broken. Try completely purging and reinstalling Elasticsearch according to our installation guide.
Step 2: Verify Zammad can access Elasticsearch and rebuild the indexes
Force Zammad to drop and rebuild the Elasticsearch indexes, optionally with a specified number of CPU cores to use for re-indexing (example [8]):
zammad run rake zammad:searchindex:rebuild[8]This should start rebuilding the indexes and output its progress:
Dropping indexes... done.
Deleting pipeline... done.
Creating indexes... done.
Creating pipeline... done.
Reloading data...
- Chat::Session...
done in 0 seconds.
- Cti::Log...
done in 0 seconds.
[...]Depending on the system performance and amount of data, this can take a while to complete. Please let this task finish completely and wait until it drops you back to the console.
If this fails or throws an error, there might be something else wrong with your installation. Make sure you followed the complete Elasticsearch set up and integration procedure according to our installation guide.
TIP
In many situations where you're not successful with above steps, you may want to check Elasticsearch's log file: /var/log/elasticsearch/elasticsearch.log.
After completing these steps, you should have verified your Elasticsearch installation is running and rebuilt the indexes.
