url: https://next.zammad.org/en/tutorials/reporting-grafana.md
# Reporting with Grafana
::: info
This guide is about Grafana. If you want to use another tool, check if it
supports Elasticsearch indexes. If yes, then you are good to go!
Grafana is a third party analytics/visualization application you can connect
to Zammad (precisely: Elasticsearch). It can access the Elasticsearch
index and visualize your Zammad data.
This guide will provide you some steps to get started. For a deeper insight
you should consider having a look at
[Elasticsearch's indexed attributes](/en/reference/es-indexed-attributes) and
to read the [documentation of Grafana](https://grafana.com/docs/){target=\_blank}.
This guide expects all requirements to be up and running. We will not cover
core configurations of each tool. Please also note that we can't support
you with configuration of your specific third party tool.
## Prerequisites
You need:
* A running instance of Grafana (hosted or self-hosted) in version 10.3 or
  higher
* Read access to your Elasticsearch index
* A Zammad instance in version 4 or higher
::: warning
Never expose Elasticsearch to the public if you're not sure how
to do it. Especially **never** without authentication! Zammad
stores **very sensitive** information within the Elasticsearch
Index.
## Setting up required data sources
**Before we start:** The data sources always follow the same scheme. We
reduced below information to `name`, `time field name` and `index name`.
Everything else relies on your environment and is out of our scope.
:::: tip
Replace `zammad_production_` with your fitting prefix.
Click on details to see how to query the index.
::: details
Adjust the following command to your environment:
```sh
curl http://localhost:9200/_aliases?pretty=true
This will return an output like the following:
```json
  "zammad_production_knowledge_base_translation" : {
    "aliases" : { }
  "zammad_production_ticket_priority" : {
    "aliases" : { }
  "zammad_production_stats_store" : {
    "aliases" : { }
  "zammad_production_organization" : {
    "aliases" : { }
  "zammad_production_cti_log" : {
    "aliases" : { }
  "zammad_production_group" : {
    "aliases" : { }
  "zammad_production_knowledge_base_answer_translation" : {
    "aliases" : { }
  "zammad_production_ticket" : {
    "aliases" : { }
  "zammad_production_ticket_state" : {
    "aliases" : { }
  "zammad_production_chat_session" : {
    "aliases" : { }
  "zammad_production_user" : {
    "aliases" : { }
  "zammad_production_knowledge_base_category_translation" : {
    "aliases" : { }
### ES - chat sessions
* Index name: `zammad_production_chat_session`
* Time field name: `created_at`
### ES - CTI log
* Index name: `zammad_production_cti_log`
* Time field name: `start_at`
### ES - ticket articles
* Index name: `zammad_production_ticket`
* Time field name: `article.created_at`
### ES - tickets by closed_at
* Time field name: `close_at`
### ES - tickets by created_at
### ES - tickets by first_response_at
* Time field name: `first_response_at`
With above data sources you basically have everything you need to start
building your own dashboards.
## Quick start with dashboard template
If you want to get inspired, you can use our sample dashboards as
mentioned below. These dashboards can also be found on
[GitHub](https://github.com/zammad/grafana-dashboards){target=\_blank}.
### Importing a dashboard
In Grafana, select *➕ > Import* (or any other place which offers you to import
a dashboard) and either upload the json file you
downloaded from GitHub or use the grafana.com ID, provided as badge
like  attached to the next sections titles.
During importing you can provide a dashboard name and folder. You'll also be
asked to map the data sources to your environment. If you used our data source
names above, you can simply search for the same name.
### Ticket statistics dashboard&#x20;
![Grafana Ticket Dashboard](/screenshots/tutorials/reporting/tickets.png)
#### Dashboard graphs
* ticket opening and closing\[^1]
* created articles
* ticket SLA (in time *and* violation) per type\[^1]\[^2]
#### Ticket and article meta information
* ticket group distribution
* sender ratio (e.g. Customer / Agent)\[^3]
* article type ratio (e.g. email, phone)\[^3]
* article content type
* escalation ratios\[^1]
* average first response, update time and close time\[^2]
* top 10 of:
  * organization of ticket customer\[^1]
  * ticket customers\[^1]
  * ticket owners\[^1]
  * average accounted time on ticket
  * ticket tags\[^1]
* last 10 escalated tickets
#### Required data sources
* `ES - Ticket Articles`
* `ES - Tickets by created_at`
* `ES - Tickets by closed_at`
### Chat-session statistics dashboard&#x20;
![Grafana Chat Dashboard](/screenshots/tutorials/reporting/chat-sessions.png)
Chat session creations.
#### Chat session meta information
* top 10 of:
  * chat tags
  * chat agents
  * chat exit pages
  * city origins
* chat topic ratio
* average number of messages within chat-sessions
* average chatting time
* world map with chat origin countries
* `ES - Chat Sessions`
### CTI-log statistics dashboard&#x20;
![Grafana Call Dashboard](/screenshots/tutorials/reporting/calls.png)
Number of calls per direction (in / out).
* call ratio (in / out)
* average waiting time
* average talking time
* top 10 of:
  * callers (in)
  * call answerers (in)
* `ES - CTI Log`
\[^1]: Some values are not available as time series information. This
means we can only display the *last* value of the field in question.
\[^2]: Requires SLA function to be active. Negative values indicate SLA
violations.
\[^3]: Specific reference IDs are not the same on every instance and thus
the panel may not work or show incorrect data. Check the panels
description on how to find our the relations on your system.
